what kv roc 412 for RR10
desertdude
SB
Hello
what would be the best kv roc 412 for my RR10 on 3s? I don't want crazy fast.
Thanks
I run a 2300 412 on 3s in mine and am quite happy with it. I have under drive on both ends and stock pinion/spur, it crawls really well and might go 10-15 mph, that's just a guess though..
Sent from my Jitterbug
How is torque twist? are you running a swaybar.
Thanks
I have a Wroncho with the the 3100 in it and on 3S it crawls awesome and is very smooth but at the same time if you grab too much throttle it will carry the wheels for a quite a distance. Its a bit much. It definitely makes my crawler fast!
yes:
MMP
Roc 412 2300
CC Bec
Hitec 7954
3s
I have the throttle curve non-linear instead of having expo in the TX, seems to be a bit smoother that way.
I'm running the 2300kv one on 3s, underdrive F/R and 18/64 gearing, hauls and crawls without getting hot. I like the wheelspeed I'm getting but would go to a 14t pinion if I was rock crawling 90% of the time. But this thing can get air easily, the Roc 412 has so much torque.
I am using the 3100kv, MMP, Castle BEC, 7954 and 3S lipo. Stock pinion/spur, stock ring and pinion gears. Very happy, definitely needs a sway bar. I am holding out for the Currie Anti-Rock if Vanquish will ever get more stock...
