Coolest Berg accessory ever made?
They are axles to suit a XR10 width Currie centred pumpkin axle, you would need to measure them to see. They may work but would need to be measured.
The stock XR10 width axle is different lengths left to right. I know this because I vended the first upgrade replacement option.
The only way to run the same sized axles was to run a front case in the rear. as it had the centred spool
Seld-M-Bend XR10 axles
Over the weekend I was trying to organize my mess of RC parts. I stumbled upon some RC4wd axle shafts. They say they are for a centered Wraith but the part number is non existent anymore. I am not sure why I even have them. LOL.
Looking a bit further into it, the RC4wd D44 shafts have the same tang as an Axial shaft.
I found the D44 narrow shafts that could work in a Berg with these lockers. These will put you close to the same width as the SCX that I am going to supply but they are a bit different from side to side for some reason?
D44 Narrow Straight Rear Axle Shafts (SCX10 Width)
I also found D44 Wide Wraith shafts that could work but I am guessing will be about 1.2" wider than a stock Berg. May no be use able but still throwing options out there.
D44 Wide Straight Rear Axle Shafts (Wraith Width)
To those who were concerned.... You can sleep well tonight knowing that I have started my hoard on XR shafts. This is not even half of what I have ordered. We Berg guys will be covered for awhile.
Funny, I was looking at it thinking maybe its not worth posting because it does not look like many.
Now I know why I can't buy an axial universals... Damn monopolists... lol
It looks like a lot of $ to me! :shock: About $1500...?
A bit better than that. Now you know why I am crying about putting so much money out on these shafts. I have bought double that amount in Wraith shafts and over EIGHT times that on the FBA shafts and that still does not include my costs on the missing link lockers.
Am I a fool for trusting in comp crawling and Bergs? I guess we will see. My bet is all on the table and I am all in. Shoot, you guys still havent seen some of the best parts coming yet (more money LOL)!
I am part of the problem for sure but I think the biggest problem is Axial underestimating the demand. I have had over 50 sets on order since December. That picture above is part of that 50 sets. I ordered more recently and I think they are on back order again for months. :roll:
On top of that, there just are not many on Ebay right now either so you know that not many people are getting many. I may have to cut everybody but the Berg guys off since we need these.
Now all we need is for some one to make some decent Berg small 2nd and 3d's to go a long with Will's RCBros gears . I 'm down to my last pair of SD hd's
All the Berg owners are hoarding those!
That would be pretty cool to have back on the market though!
Something much better is in the pipeline for gears.....
If you guys liked the axle picture, I should have posted these before taking them all apart. They are all orphans now. I have plans for the 8mm inners and the long side Wraith. I just need to find a good home for the short side Wraith shafts.
[/URL][/IMG]
