pcrescenti
Playing and testing a little the new toy.
Had so much fun with it!!!
Sounds like it's skipping a tooth somewhere (axle or transmission). Remove the upper link screw and put a small washer on it before reassembling the link to the mount. I'll try to find a pic to help illustrate what I'm talking about
CMS is chassis mounted servo. It moves the servo off the axle and onto the chassis which looks more scale. The down side is you put that weight a bit higher and some CMS kits can give you a bit of bump steer if they are not setup correctly. If you go this route, the easiest thing is to buy a whole kit instead of piecing things together. The Locked Up kit is nice. Setup is a bit more involved than some of the others (Vanquish) but it is more adjustable and you can get rid of pretty much all bump steer with that kit.
All the internals from the stock housings will fit into the SSDs housing. The links will also bolt right up.
Many aftermarket wheels use SLW hubs. You can play with different widths to get the offset you want. They do run $15-20 per pair so randomly playing around with widths can get expensive. There is a vendor here called Lattice Innovations that has an adjustable kit that is very nice. I think it was ~$40. If you are going to use the stock wheels you could try different width hexes but you will not have a whole lot of options.
ETA there are tons of threads on relocating batteries to the front. Some vendors make different rock sliders that allow you to strap a saddle packs on or you could just add a plate onto the stock sliders.
From a purely performance standpoint, having the servo on the axle is better. It keeps that weight lower and you can just 4 link the front, which is pretty simple. CMS looks cool and its more scale. If you are going to do any scale competitions, it will get you a few points.
SSD axles are the same width as stock. Hubs are the easiest way to play with your width. The hubs I mentioned in my other post allow you to really fine tune it. You will need to provide your own M3 screws, which brings up another good point. If you are going to be modifying a lot, a good M3 screw kit is a necessity. I bought a big kit from Screw Loose, but KNK is another vendor that sells them.
I dont know much about Vanquish wheels....they are nice, but they cost more than I care to pay.
Have you checked your diff gears? Just a thought.
Sent From My Galaxy S6 Edge+
Rubber mirror for Jeep JK 1/8 | RCMODELex - specialized for RC rock crawling, trial and expeditions
RC Modelex sell some rubber mirror for the New Bright JK![]()
Not sure if you fixed your that noise yet but it looks like a driveline issue to me. Almost identical sound as a friends Falken g6 jeep. Make sure the pins @ each end of the shafts are aligned properly. If they aren't it can cause binding issues.
Yeah, both ends. While you have the shafts separated I recommend that you spin everything to make sure it's not binding. Spin front axle @ the pinion no drive shaft attached. Same for rear axle. Same for the transmission/motor. If everything is rotating smooth then align the shafts, one @ a time and spin it. Sounds like more work than it really is but believe me, if it's something else it should show up pretty easily. Also check your pinion angle just in case.Hey Shift, thanks!
The pins have to be parallel in the both ends of the shafts?
Tomorrow i think the 4link it will arrive and i will open it... install the kit and see in the axles if the noise should be overthere, or in tha shafts as u said!
Thanks a lot!
Awesome!!
does that fits the New Bright Body? it have to plug just in the door.
Thankss
Yep they are an exact copy of the original new bright mirror, but in rubber
What fenders are you going to use ?
