BarHarborBasher
No problem!!
First things first you have to identify which pinion you have.. A couple of months ago Axial started including the HD Pinions in the RTR & KIT models after I presented them the issues with the defective design months prior...
So you may have the gears already...
Right now The DHAWK V2 bulkhead is the only housing that works with the Factory HD gears.. not even the Axial housing work with the gears without the mod..
And yes you will need to sets..
Limiting straps help keeping everything together!!
Rear traction bar is a must
And a aluminum front clip (batwing) or my BHB basher bar..
Aluminum steering rack
Front shock retainers.... oversized washers or a horizontal bar like mine and shock tower supports ..
Good bearings and a rear driveshaft boot to boot...
I've modified my transmission which has held up great!!!
I installed tight fitting pins that eliminates the SLOP in the (pin to shaft) fitment as well as the slop in the ( pin to gear pocket ) fitment.. I working on a mod one transmission conversion..
If you want me to mod you up send them my way if you're not in a rush..
