Yep
I'm toast
He's not done rubbing his greasy fingers all over every part. :ror:
Quiet, you!
This is the first RC4WD kit I've wanted.
Yes you do... :mrgreen:
How did you get one so fast?? Can't wait till mine arrives
The kind folks at RC4WD were kind enough to give team drivers a chance to get a few early. "thumbsup"
only slightly jealous here... only slightly
Yeah, right. Slightly. Sure. :roll:
My long wrenching session last night was quite productive. Before I get on to the build, let me start with a few quick observations, starting with the packaging. I've long been a big fan of the RC4WD packaging with separate little styrofoam compartments for each of the major metal pieces. RC4WD is now doing the environmentally responsible thing and reducing the amount of packaging material needed for the kit. So no more styrofoam layers with fun little compartments. But even without all of those nice little compartments, everything is very easy to find. There's a sealed bag for the rails and 3 big bags for the rest of the parts (one for drivetrain components, one for plastic parts, and one for the metal hardware and parts).
Easy enough. I’ll miss the Styrofoam compartments, but this is the right way to do it. Well done, sirs.
RC4WD has also been working on upping its game in other ways, as well. I noticed a few nice improvements as I went through this one, including well-greased drivetrain components to help everything last a long time, and 14mm starter screws for the wagon wheels so it doesn't take as long to put them together. Thanks, guys!
So…back to the build. If you’ve built a TF2 kit before, you’ll be in very familiar territory. RC4WD had the good sense not to mess with what was already a very good thing, using the same components that have worked so well for so long in the standard TF2. Directions are typical RC4WD. Simple, clear, uncluttered, easy to follow:
I decided it was time to add some scale bling to my work bench, so I picked up a set of Chubby Mini 3 Ton Jack Stands:
I know it's not a full-on scale garage, but everyone has to start somewhere, ehhh? I’ll get some comparison shots to other chassis later on.
The chassis goes together just like a standard TF2, with the addition of 1 extra cross member for the coupler that extends back from the t-case (more on that in a minute):
In case you were wondering, mounting points for the sliders are spaced farther apart than the standard TF2, so regular TF2 sliders won't work:
As with the standard TF2, Gelande 2 hoops are a must to get longer suspension travel up front:
And as with the standard TF2, the battery tray has two mounting positions:
Since I'm planning on a full interior, I'm not sure which one will work better. It's easy enough to move, so I’ll come back to that later.
Here's the chassis in its entirety:
So long for now.
