New SSD HD Titanium Link Sets
SSD
UK
For WB2
Complete titanium suspension link set
Includes panhard bar
Internal thread
Direct fit onto Vaterra Ascender using stock Vaterra rod ends
Suitable for Ascender WB2 290mm wheelbase (Chevrolet K10)
5 X 78mm Titanium links
2 X 66mm Titanium links
1 X 61mm Titanium link
16 X M3 x 12mm threaded rod
HD Titanium Link Set for Ascender WB2
For WB4
Internal thread
Suitable for Ascender WB4 314mm wheelbase (Blazer)
4 X 90mm Titanium links
3 X 78mm Titanium links
1 X 73mm Titanium link
 HD Titanium Link Set for Ascender WB4
Thank you SSD. We appreciate you continuing to support and expand your Ascender line when so many other companies wont. "thumbsup"
Just got suspension and steering sets in the mail... These should be alot smoother over the rough stuff
Tapering Ti is not an option really.
No as there is not WB3 Ascender right now unless I am mistaken.
There is no wb3 of of the box but there are several body options in that place. The early model bronco body from proline being one which I have sitting on my shelf at the moment.
Sent from my SM-T320 using Tapatalk
The threaded rods that connect the ball ends that I got in my steering and suspenson link kits seem a few mm too short. If I bottom them out in the rod ends, there is about 3mm to 3.5 mm left to thread into the links. Is this enough??? If I do this, when I threadlock the threaded rod into the ti link, the hex would be on the inside and ill never get them out.This question is aimed at SSD
The ones I received are 12mm. 14mm would work, but16mm would be perfect. Does anyone make these in slightly longer lengths? I would like to bottom them out in the ti links with thread lock leaving the hex on the ball end side.
Assuming they are the same thread pitch, axial has some M3x16. AXA186. That might be what you are looking for.
Ok... So im very happy all the titanium links in the ssd sets. But the hardware is too short. I'm keeping the steering and panhard bar, and upper links, but will dump the lower links at cost. Ill pay shipping. What should I price these at? 20$?
I really like the Vattera 1 piece links for the bottom
Is there a formula for link lengths for extended WB Ascender chassis? I'm looking at getting a custom chassis for a longer rig.
Not any formula, ya just gotta decide on the wheelbase, build/buy links accordingly and keep in mind the F/R links length. Generally rear links little longer than rear. :)
