Ditchrat
Well I went to order another V3, and wouldn't you know it, it has been replaced by a V4. From the description...
420oz-in v4
You're looking at our newest S420 servo, the S420v4. While it looks a lot like the S420v3 it replaces, just like a Porsche 911 looks similar year-on-year, our engineers also apply what they've learned to make iterative improvements. For example, in going from v1 to v2 we improved the gear material (from brass to steel because steel wears better). With the introduction of the S420v3 we went to massively larger steel gears (and a finned case for better cooling) because top modelers were abusing servos like nobody else on the planet. Using what we learned results in better servos for everyone. Now, with the S420v4, we've done something else never before seen in aluminum servo cases - hard points. Pressing a harder material (brass inserts) where the steel gear shafts fit the aluminum case enhances durability and results in greater precision, which is important.
Can't say I have had any issues with my V3, but I guess progress happens. So its in the mail, when it arrives I'll be taking it apart to check everything is water tight so I'll see if I can get some pictures of the internal changes.
420oz-in v4
