Does anyone heard about this! Does the specs says it is a good to buy or not?
Product Description
The original upgrade waterproof 3660 3800KV brushless motor with 60A ESC combo is designed to provide both quality and performance at an affordable price. Waterproof function motor and ESC let your car challenge the muddy road. Providing much convenience for your 1/10 RC car truck.
PSClick the link to watch the product video: https://www.youtube.com/embed/PZ3c92A6isM
Features:
4 pole 12 slot high-torque motor design
5mm shaft diameter
High purity copper windings maximizes efficiency
Precision engineered for maximum energy conversion
Precision balanced rotor,smoothness for best reliability and maximum RPM
Mutiple protection features: Low voltage cut-off protection, over-heat protection, throttle signal loss protection
Bulit-in 5.8V/3A BEC
Suit for 1/10 scale RC car
Motor Specifications:
Brand name: GoolRC
Watts: 1200W
Max voltage: <13V
Max Amps: 92A
KV(RPM/Volt): 3800KV
Max RPM: 50000
Diameter: 36mm
Length: 60mm
Shaft length: 17mm
Shaft diameter: 5mm
Plug type: 4mm golden banana plug
ESC Specifications:
Brand name: GoolRC
Item name: waterproof ESC
Continue current: 60A
Burst current: 320A
Battery: 2-3S Li-Po / 4-9S Ni-Mh Ni-Cd
BEC output: 5.8V / 3A
Power supply plugs: T plug male
Motor plugs: 4mm banana plug female
Dimension: 50 * 35 * 34mm / 2.0 * 1.4 * 1.3in (without cables)
sent by Wehlee
Product Description
Features:
5mm shaft diameter
Brand name: GoolRC
Watts: 1200W
Max voltage: <13V
Max Amps: 92A
Max RPM: 50000
Diameter: 36mm
Length: 60mm
Shaft length: 17mm
Shaft diameter: 5mm
ESC Specifications:
Brand name: GoolRC
Burst current: 320A
sent by Wehlee
