The pile of goodies I started with:
After dremeling the heck out of the battery tray:
The chassis brace (a turnbuckle) I used to re-enforce the chassis after all the dremeling.
Notice the peice of hard foam under the servo. I've heard the servo can use some help as it flexes sometimes. This foam spacer has the servo sitting squarely on the chassis instead of being suspended.
So now I have to make a battery holder somehow. This is a large tamiya ball stud and a standard battery strap buckle pops onto it perfectly.
I shortened the strap by folding (and stapling) a section of it, and then wrapped it around my new chassis brace and it worked really nice.
For electronics, we have the RC4WD 80T motor, an SCT sidewinder programmed for brushed motor and crawling, and that's a 200oz servo like I use in my clodbusters.
Even after cutting the stops of the c-hubs I had to dial back my steering servo. I'll probably dremel a little more in time, but I think this is a good start. This is limiting travel to right before the steering binds/hits the c-hub.
Had this Hummer body, gonna' use that at least for now (till I can trim and paint the bronco.
