soze
Soze's G-Made Sawback 4LS
This is pretty much my first scaler/crawler type R/C. Pretty average normal build and nothing crazy like some of you more talented folks out there.
Follow this build on YouTube - https://www.youtube.com/playlist?list=PLnWfHyV3LtMBL94b2Y9BSpTH1aFcEuuaO
Most product links are to the item on eBay. As an eBay Partner, I may be compensated if you make a purchase.
Kit:
G-Made Sawback 4LS Kit - https://bit.ly/35AJQWQ (Amain)
Parts:
G-Made Zero Ackerman Knuckles - https://ebay.to/3pc25Zb (eBay)
G-Made Zero Ackerman Steering Links - https://ebay.to/379Oj36 (eBay)
G-Made Aluminum Hubs - https://ebay.to/3ph4Xny (eBay)
G-Made Brass Axle Weights - https://ebay.to/378LteR (eBay)
G-Made Rock Sliders - https://ebay.to/2MYOMyc (eBay)
G-Made 19x58 Soft Springs - https://ebay.to/3jNmbbo (eBay)
Red Tow Shackles - https://ebay.to/3qfIwk4 (eBay)
BoomRacing Aluminum Servo Plate - http://bit.ly/2FlqwAG
JunFac 80012 Heavy Duty Rear Bumper - https://ebay.to/3tNP4J3 (eBay)
Electronics:
PowerHD 23KG Waterproof Servo - https://ebay.to/2ZerlDy (eBay)
GoolRC 27T Brushed motor - https://ebay.to/3ai7hqt (eBay)
FlySky FS-R6B 6ch Receiver - https://ebay.to/3qdJGg3
FlySky GT3C Transmitter - https://ebay.to/2NlfqBa
Tools:
Versachem Brake Caliper Grease - https://ebay.to/3p8bIZ7
Noleen SF3 Grease (available on eBay) - https://ebay.to/3jN9vB9
Permatex Anti Seize Lubricant (ebay) - https://ebay.to/3qpTbsN
Associated 1656 FT 1/4 in Driver Handle - https://ebay.to/3d31t5O
Tamiya Side Cutter - https://ebay.to/371SAWb
DEWALT DCF610S2R 12V MAX Cordless Lithium-Ion 1/4 in. Hex Chuck Screwdriver Kit - https://ebay.to/3tQqXcr
MIP Metric Speed Tip Set MIP9512 - https://ebay.to/3qdBMTU
Bob Smith Industries Blue Thread Locker - https://ebay.to/3jDR8i9
ProTek RC Shock Pliers (available on eBay) - https://ebay.to/372Lscs
Duratrax Shock stand - https://ebay.to/2MOyJ6l
Hakko FX-888D Soldering Station - https://ebay.to/3aXFmLj
Multistar Rubber R/C Work mat - https://bit.ly/2T3F4Zo
IWISS Crimping Tool - https://ebay.to/3jGKZll
Universal Servo Cable Wire Connector Crimp Pin Kit - https://ebay.to/3tSAAaW
E6000 Adhesive - https://ebay.to/2MZwtZV
I always forget to take pictures while I'm building.
Chassis pretty much built
A look at the Zero Ackerman Setup
A look at the electronics & motor have not started to clean up wiring yet.
Started paint on the body
Masked with masking tape only to find out later that the light kit included light masks!!! Grrrrr :x
Test fit.
Started applying decals.
Started wiring up lights
As it sits right now.
My first flex shot. Am I doing this right?
More to come. Sliders and brass weights are arriving today.
I have some ideas of what figures I want to use for the driver. Trying to decide if I should cut out a footwell so the figure will fit.
Also plan on getting scale accessories for the vehicle as well.
Kit:
Parts:
Electronics:
Tools:
Test fit.
