*** Krazed 1100's Delrin Slug Holders
Robbob
Custom Carbon Fiber
Moderator
Connecticut :(
Machined Delrin Weight Holder
These are machined delrin holders for the Pinewood Pro Tungsten weight slugs. Getting almost 100% of the weight below your axle center is important. These holders allow you to do that.
Included:
2 Delrin holders
***There are a couple things to know before ordering, they may not fit all wheels out.
What we do know they fit are all the plastic glue on wheels, Y-town Crawlers P-1 and all Krazed Builds wheels.
You need a minimum inner diameter of 1.85'' to clear them.
You can also shim them out to possibly help clear the carbon fiber rings if they rub.
Whats Needed:
Tungsten Weight slugs -> Tungsten Cylinder Weights 3oz
RCBros Bully2 weight holders for Bully2 axles ->Bully 2 Knuckle Weight Holder |
RCBros Wraith/XR weight holders for Axial axles -> RcBros Two Ear Knuckle Weight Holder |
$10.00 a pair
Available through our webstore -> 1100's Delrin Slug Holders
Hey I'm trying to get more info on these and want to adapt them to a 2.2 scaler comp rig. Do these fit inside the backspacing of beadlock wheels? if so, which ones?
You need minimum of 1.75'' diameter spacing between your bead ring screws or use plastic wheels like Crawler Innovation 6Bolt or similar wheels.
Put the wheel together and measure from
Wheels I know they fit:
Krazed Builds
5th Dimension
Y-town P1's
Crawler Innovation 6Bolt plastic
Plastic DE wheels (offroad vehicle styles)
Also, depending on what beadlocks your looking at, if there's enough room you can add spacers and push the weights out to sit in the middle of the rim, in between the beadlock rings. That's what I did with stock bully 2 rims.
Krazed Builds
5th Dimension
Y-town P1's
Awesom, exactly what I was looking for.
I'm actually looking at the Vanquish SLW 2.2 Comp Beadlock wheels and it looks like it might barely fit in there.
SLW V2 Black/Clear Anodized 1.0in Wide - Vanquish Products
anyone know for sure?
Yup same thing I did on my shafty truck and on my pro I used rcbros brass half weights.
Sent from my 0PJA2 using Tapatalk
