Mountainsofbeer
This is beginning to be the one of best threads in the TRX4 forum lmao.. its stupidly funny yet there is some good modding and info in there. I'm going to give you a great Yelp review
Awesome build. Quick question, do those style of winches have issues with getting tangled on the spool. I'm just curious since its enclosed inside the body and must be hard to baby sit.
I just picked up the BowHouse battery box and rear crossmember, its my first experience with 3D parts and I'm pretty impressed.
Keep up the tomfoolery. I like hearing about it. In a mostly picture related way. The writings not bad either.
Will you do a overall turning diameter test with the different diff locks to answer if it turns tighter with only the front, or only the rear diff locked? Inquiring minds must know.
"I am a highly important executive that keeps things at a large company operating effectively" sounds fishy. The other three though are pretty reasonable.
I have a wife and 2 young children that keep me busy
I fight crime as a masked vigilante at night using my vast resources of high tech equipment
I have another 8-9 trucks I am currently working on including 3 that have potential to be run at the GCM Adventure Series even in a month
I take it the Castle power plant has been holding strong? It's omission from the above post tells me it's fulfilling it's mission of deliver stock-like power with more efficiency and less heat. I presume it also handled the water ok?
glad to hear the prolines are serving you well too. You get a chance to run those through mud at all?
I agree on them nailing it on the shocks. They feel very different compared to what I'm used to and even what works on my axial stuff but different is perfect for this very cool truck that now out crawls my fully built 10.2 while being able to transform into a wheelie machine that does Donuts and some lifted short course activitySo I guess I have to start this post out with a confession (since someone totally narced on me).
My wheels and tires are not stock. Enjoy this picture while the shock sinks in:
Multiple people have tried to convince me the stock tires are legitimately good tires since they are soft, relatively sticky, fairly aggressively treaded, and the foams are close to being good. I remain defiant in saying they are good RTR tires and nothing more. The more I drove with them, the more I felt they slid off lines and hopped while looking for traction on climbs. So, yes they are probably the best tires you can get on a RTR truck (for reasons previously presented to me) but I don't see people actively choosing to run these over other established tires.
In addition to my well reasoned points above, who wants to run stock tires? Lame. Enter the Proline BFG Krawlers with Proline 2 stage foams. They look good and, in the words of Kyle from UCFab, provide all the traction of Hyraxs (Hyraxes? Hyraxen? Hyraxi? I'll Google it later) in a licensed tire. It is everything I could have ever wanted. Proline's 2 stage foams are my new favorite for Proline tires: the fit, sidewall support, and tread compliance are all perfect on the Krawlers. Who knew a company that has been making RC tires for 30+ years could make a foam that works so well with their own tires?
Stock wheels are also lame. Gear Head wheels are not lame, they are shiny and wonderful. These 12 pack EZ locks were the result of receiving some money for Father's Day and RPP having a Father's Day sale at the same time. Like the scale lugs? They are Locked Up M2 acorn nuts and M2x10 set screws since the Gear Head wheels are too thick to use the standard Locked Up M2 wheel studs. SSD hubs are also a recent addition but they will be staying.
Confession #2: I didn't buy pre-dirtied tires, I drove my TRX4.
Let me set scene: it was early Sunday summer morning but you could tell the day was going to be a hot one (since they all are in North Carolina). Two intrepid explorers set off into the empty woods lining the Haw River in search of tiny truck adventures.
Got it? Moving on.
I brought along my new and improved TRX4 while my fellow explorer brought along his Wraith (mostly because he can't stop breaking his other trucks). I threw in a freshly charged 4000mah 3S pack and we were off.
We trekked through rugged terrain,
over mountains,
forded the rivers and streams,
squeezed through tight spots,
and over some dangerous ones.
We returned to camp 3 hours later; tired, dirty, and hungry. So we ended our journey the way all great adventures should: at Bojangles (look it up if you're not from the south, this post is long enough as it is).
The time of reflection is at hand.
First, the Castle 2280kv motor and Mamba X does every good thing about the stock brushed setup as well or better. Low speed control, drag brake, top end wheelspeed, all just as good as brushed. The big difference is heat or lack there of. In 3 hours of constant running mixing low gear, high gear, crawling, climbing, high speed passes, and general tomfoolery, the motor and ESC were barely above ambient temperature (which was in the 90s by the end). The stock setup would have reached that level in 15-20 minutes. 4 servos didn't even tax the Mamba X's internal BEC. It was a very impressive debut for the new motor and ESC.
Independent diff control is just fantastic, the flexibility it provides adds another level to the driving experience. Unlocking the front as you come off an obstacle so make a tight turn setting up the next line or unlocking the rear to let it slip and prevent a backflip are just some of the benefits I encountered. Besides, this is America! The answer is always everything. When someone asks "chicken or burgers?" we say "YES!" When someone asks "front or rear diff lock controls?", we say "YES!" to that too.
The Proline Krawlers are lovely upgrade. They get traction everywhere; dirt, rocks, mud, wet, dry, sand, gravel, baby oil coated glass (I assume). You get the idea. More importantly, they consistantly hold the line you want to take and exhibit little wheel hop when searching for traction. They look cool too, that is as good as reason as any to change something on a scale truck.
Now for the steering servo. The Power HD 23KG servo is much better than stock so it has that going for it. Otherwise it is loud, whines as it constantly looks for center, and probably has less torque than it is rated for. I was able to completely stall it out on a few occasions that I didn't think would give it so much trouble. At least its not dead so there is that.
The stock suspension is on point for a heavy body rig. A lot of people will run for a bottle of lighter shock oil because they think they should based on their other lexan body trucks. When you have a heavy, top heavy body, controlled suspension movement is what you want, that means heavy dampening to slow the suspension's reaction to the shifting body weight. Traxxas pretty much nailed it out of the box.
Nothing has broke, nothing looks worn, nothing feels loose, the body is still perfectly in tact. All in all, life is good. There is now nothing this truck needs. Good thing that has never stopped me before.
Glad to hear the MX and 2280 combo works so well since that is exactly the combo I have on back order from Castle. That said I have not seen any heat issues on the stock ESC and motor using 2s batteries which I seem to prefer over the 3s. May revisit the 3s once the MX and 2280 get installed.
Radiation poisoning? Pfft. Come on.. Man up! :mrgreen:
