92fox
Having an issue with my stock ESC that started today. Took the rig out to play, and out of nowhere it would go slowly in reverse with no throttle input. I took the body off, and tried to turn the ESC off with no luck, so I unplugged the battery. When I plugged the battery back in, the ESC blinks rapidly with the green LED.
The manual tells me that this means the ESC is not getting signal. I checked the wires from the ESC to the receiver, and all are good. All other servos work fine. Battery is good. Batteries in the transmitter are fresh as well. I've checked the neutral setting on the controller, and its in the normal position (50/50). I've never touched anything in the menus before, but reset the transmitter and end points to be safe. No luck.
Is my ESC fried?
Is my ESC fried?
