HiTec X2 Plus Charger issue
Digital
Chico, CA
So I'm trying to setup the memory for different battery packs.
On Prog. A, the memory works corrrectly and shows 2.2A.
On the 2nd port, (Prog. B), I have the memory set for 4A (4000Mah 2S). When I switch to LIPO mode it shows 2.0A??
No batteries are connected, what am I doing wrong?
Most likely nothing, the second port is set to give 80% of what the first is. I don’t think that can be reconfigured
Hang up and Drive
Hang up and Drive
Hey Mike, I don't know whats going on, apparently it's doing the same thing on Prog A...
Just so I'm not crazy, if I'm going to charge a 2S 4000mah battery, I do that at 4 Amps correct? Discharge also at 4 Amps? Discharge voltage at 3.3v? Maybe my settings are wrong and it's a safety thing or something...I dunno.
"Adjustable Charge Current Rate of 0.1 – 10.0 Amps Each Port"
The built in program is set .
When charging thebattery as stated you are correct, but if you try two at 4000, the second is maxed at 80%. This is from memory of the manual
Hang up and Drive
That's my problem i think Mike, I go to the memory setting and hit the enter key on the memory setting that I configured but it doesn't load or I'm doing something wrong here.
Sent from my Tin Can using Tapatalk
Apparently if you press the Enter key briefly, it sets the configuration for that Memory setting, then if YOU HOLD ENTER for 3 seconds it applies that selected memory setting...
Either I had too many beers last night or I'm just retarded....maybe both. But it's works as intended now. "thumbsup"
