I'll be using metal gears on my build, placing order today.I wonder if metal gears would help (if they are machined properly)
Here are the details of your order that was placed on 2018-03-01 07:17:22 at JunFac. You have used $457.20 paypal.
I'm definitely a GMade owner now. :shock: I'll start a build thread soon.
Yeah that snap ring holding in the pin seems be the weak point. Being just 1 loop instead of multiple loops wrapping round it the pin has a chance to work its way past the snap ring at the break in the ring. I tried to orient this break in the snap ring away from the ends of the pin, though I would be surprised if it moves around later on.
I'm going to check the hardware store for little metal zip ties later today. If I cant find anything to fit I'm thinking a smear of shoe goo might help to keep the ring in place while being something that could be cleaned up later if needed.
EDIT: one more idea, maybe there's better snap ring available in the same size? its 12.7x0.7mm
I am going to check if its possible to just simply add a second ring.
I don't see there being enough room for that, its really only wide enough for the ring they provide.
Though I do have 2 retainers from a Tamiya axle set which is much thinner but its 3 loops, its too wide and would need to be cut down some.
For now I'm gonna try some CA glue
I just fitted some 2x12mm pins in the CVA's last night and took some measurements and pictures http://www.rccrawler.com/forum/g-made-crawlers/595532-humboldtefs-gmade-gom-build-2.html#post5806580
Try the tire glue.... it really works on the ProLine axles....... same deal
Hang up and Drive
I'm willing to bet it is/was the smaller pins causing problems. This isn't really a new design they are using so I'm blaming inferior materials for now.I'm interested to hear how Humboldt's 2x12mm pins work out.
For those of us waiting for aluminum dig forks to return to stock, I received an email from Greg @ Active Powersports saying he expects them in around the end of the month.
Just wanted to pass this along. Hopefully other vendors will be getting their stock around the same time.
