BAJAREY2017
Had some of these laying around that I never used and they look pretty close in length as the stock shock shafts. Does anyone know if they will work. I won’t be able to use the Ascender pistons unless I drill the center out and use a clip to hold it in place. I guess the only benefit would be they have the nitrate coating so less stiction and they would look cool with the gold coating.
I always use associated slime but still ends up leaking. Next time I rebuild I’ll use the x rings.
Hope this works. Going to try it as soon as I get a chance. My new aluminum Vaterra shocks are leaking on my Ascender and all I did was run it to check my new electronics. Great looking shocks but leaking is not cool. I have lots of those Traxxas rebuild kits at are shop so will try it. Got my fingers crossed.Pick up 2 packs of the Traxxas shock rebuild kit # TRA2362
$2.50 each. Throw away the Vaterra o-rings. Just use the thin washer in-between the X-rings and coat them in associated green slime. When screwing on the caps do not tighten them , you want them to be just a tick over snug. Then enjoy some leak free shocks.
That's better than my situation, working 20 or so days away from home and can only get my fix by reading everyone's post and dream about what I can do when I get days off. So everyone please help my sickness and post up some good reading or good movies. Thanks!Watched it pull in the parking lot and then drive off. Stupid FedEx driver pulls in, walks up with a missed delivery tag, and then drives off before anyone could get to the door.
Sent from my SM-G955U using Tapatalk
Not when 30 or so knuckleheads keeping me busy all repairing 30 or so pieces of equipment, but I've been thinking on getting a 1:24 crawler to buzz around the well site.Pick up a Twin Hammers. Small enough to fit in a backpack and be with you most anywhere
