Beautiful build so far - like all of your builds.
Would you mind measuring the diameter of those 1.9 MTR tires mounted up? They're on my short list, but I'm thinking they might be a little tall.
Do you have contact info for pimpin crawlers? I would much like to have a custom chassis built.
Thanks Lee
I'll have to find him here, I don't do fbHe's PIMPNROCKS on RCC and search Pimpin Crawlers on FB as well.
4.70 mounted. I have the same tires in 2.2 and really like them. They have nice internal sidewall bracing too.
Thank you very much! "thumbsup"
That's a little tall. I wish we had options at 4.5".
I just mounted the 1.55 MTRs tonight. Cool tires, but the fact that they are all the same rather than mirrored drives me nuts. The right side tires look backwards to me.
I see you are using the new incision scx10.2 rtr dive shafts ... did you have to modify them to work with the scx10.2 kit transmission ....The spec list so far:
Mamba Max Pro ESC
Holmes Hobbies Puller Pro 2200 kV (Standard Length)
Castle BEC 2.0 Waterproof
ProModeler S7440BLHV Servo
Spektrum RX
I'll be using the 10.2 kit version transmission reversed to offset the additional rearward chassis weight.
Vanquish SCX10.2 Transmission Top Shaft
Vanquish SCX10.2 Motor Plate; Black
BowHouse RC Forward Mount Transmission Cradle for SCX10.2 Kit
Incision Driveshafts for SCX10.2 RTR & SCX10 (reversed due to trans flip)
Incision Stainless Steel Panhard Link
Incision Stainless Steel Drag Link
Incision Stainless Steel Tie Rod
Incision Stainless Steel Upper Front Link
SSD Stainless Steel Lower Links
Axial Aluminum Rear Upper Links
STRC Front Shock Towers w/Panhard Mount
TRX4 GTS Shocks
Vanquish Currie RockJock SCX10.2 Front Axle
Vanquish Currie RockJock SCX10.2 Rear Axle
Vanquish SCX10.2 Spools
SSD Heavy Brass Knuckles
Axial AR44 Universal Front Axles
Axial AR44 Rear Axles
Hot Racing Heavy Duty Steel Bevel Gear Set 27T / 8T 3.375 Ratio (Front Axle)
Axial Heavy Duty Bevel Gear Set 30T/8T (Rear Axle)
RC4WD Billet Fuel Cell
<a data-flickr-embed="true" href="https://www.flickr.com/photos/156142005@N05/42062219391/in/album-72157696736717925/" title="PowerWagon_003"><img src="https://farm1.staticflickr.com/970/42062219391_f67fa4e23e_b.jpg" width="1024" height="576" alt="PowerWagon_003"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Did you use the bowhouse battery tray also to reverse the trans?
Awesome progress on the build so far Bil! I really dig the radiator you built and very nice choice in wheels and tires. She's going to be a beast on the rocks thats for sure!!
