Magnets vs velcro vs clips
AnimalHippie
Ocala, Florida, USA
Hello everyone, trying to get my truck bed mod finished up & having trouble deciding how I should do body mounts for rear. I see allot of people saying that using magnets your going to have the body falling off. I don't want that for sure. I still have clips in the hood holding that on. I have room to do the clips, but would rather have something not visible. Only if it's going to work as good or better. Just wondering from your experience what's the best way to go? Thanks for any and all info! Have a great day!
Velcro strip on a rectangular flat piece of plastic mounted across the body post mounts works for me, and will be the approach on my current build...provided you have some means of alignment, which you have still using the hood pins. Sorry no pics handy. Tried magnets...no bueno for me.
Magnets suck for off-roading. Any tip over and it'll dislodge the body in me experience.
I keep the clips - simple and effective.
I designed these body mounts to use 60mm x 10mm magnets. The part that attaches to the body captures the chassis mount so it can’t slide around. I just got the magnets and I plan on using either epoxy or shoe goo to hold he magnets in the mount. I think the weakest part of the system is the bonds between he layers of filament. I can update once I get the magnets installed and run it a few times.
if you go the velcro route use Dual lock instead of the traditional velcro its much, much stronger.
I just did up some magnetic body mounts for a hard body using ring magnets (rare earth) which are much better than those without a hole in the middle as they locate themselves. They're quite strong but I'm only using them here since its on a scale truck and should take a lot less abuse.
I bought some velcro that's says it'll hold 15lbs I'm going to give it a try. Couldn't find the dual lock anywhere local. C-MuRdaA keep up the good work & please keep us posted on this. I'm very interested to see how it works out for you.
If u use magnets use washers the the magnets r just big enough to fit in the middle of them they seem to wprk better
Sent from my LG-M703 using Tapatalk
I installed the magnets yesterday. So far the mounts and the magnets are mounted using shoe goo in case I decide to change them up. I’m linking a quick video where you can get an idea of how strong the magnets hold. The front of my truck is super heavy so it’s easier to pop he body off that way. If the truck rolled down a hill and the body go caught up on something I have no doubt that the chassis would separate from the body. For a basic rollover these magnets (60mm x 10mm x 3mm will be fine.
I have a few options.
1: use two magnets side by side to get more force to keep he body on
2: Make two more mounts (either with or without magnets) that hold the body on the sides that would help keep the body on. I would uses a similar style mount as pictured above but bolt it into the mounting space for the stock sliders.
That part will bolt in and I’d make a “box” that would fit over it. I modeled that piece in about 20 min and I plan on printing it tomorrow and test fitting it before moving forward.
Here’s a link to the current setup.
https://youtu.be/NUMc_8YrVPw
Do you plan on putting scale accessories in said truck bed? if so, perhaps have some scale accessories cover the clips, with said accessories themselves being held on with magnets. The security and ease of clips, while maintaining scale visuals.
I made these little brackets that bolt into the holes for the stock sliders that will help keep the body on. Once the shoe goo cures I’ll take it for a test drive and see how my whole system holds up.
With the four small mounts I added I can now pick up the truck by the body and it won’t come off. This truck weighs a ton too. I’m probably going to fine tune the new mounts and then post all the stuff I made on Thingiverse so people can print their own.
https://youtu.be/5HxDA6dZJ4Y
