tapped-out
Voodoobrew I sent you a pm
Sent from my SM-J737V using Tapatalk
How to setup a Radiolink 6 channel transmitter and receiver to a RS10XT and still have the steering choices.:roll:
I’ll have to circle back for the revolver bearings. I don’t have one at home to measure.
Puller motors are timed at lowest amp draw and not physical timing. Part of this is because zero isn’t always zero due to variations in the armature. The other part is the magnet design. It does not allow for timing advance, motor efficiency goes down faster than power goes up. The motor is specifically designed for crawling, so the magnetic circuit trades off timing changes for much much smoother startups. Brush wear and arcing is not an issue at “zero” like normal motors, which is also due to the magnetic design.
The Puller is non standard in this regard. Everything you would normally assume about timing advance does not apply.
Do you ever perform the "motor test" in the Castle Link software and/or do you ever set Torque Limit? I can't think of why you'd want to do that.
Also, are you the Holmes bicycles guy?
Also, when are you getting full-size 1800kv Revolvers back on stock?
Isnt this something you can get from the data loging?
Ive not realy used data logging except once but I think it had amp draw on it.
I would never lock up the tires and hammer down to find the max amp draw though and I think that's how you do it. maybe you have to add resistors in line to stop it from cooking.
