Voodoobrew
Last I read holmes has not used the hobbywing 1080 to answer this. But I want to know as well. Even though I don't think I could ever be happy with the sound of an out runner.
How would you rate the mamba x against the HW1080? I too have the Mamba X and a revolver 1800 in my trx and am very happy with it (even with the sound). Curious about the crawlmaster now, but I think I would still prefer brushless over brushed simply for longevity.I have 5 TRX4s 1 of which is equipped with a Mamba X and 1800kv Revolver in my #1 chassis. The remaining 4 TRX4s all have HW1080 with various motors ranging from the stock Titan 21t, HH Trailmaster Sport 550 and a pair of HH Crawlmaster Pro 550 12t. My favorite combo is the the HW1080 and Crawlmaster Pro 550 hands down the smoothest slow start up.
Ahhh...I never really looked into the HW and thought it did both. I think I'll stick with brushless though. The low speed control and startup is plenty good enough for me....even sensorless.Remember the HW 1080 is only for brushed motors... I have it paired with a HH Trailmaster Sport 550 21t in my Ascender and also have one to be installed in my TRX-4.
It's a fantastic budget setup, but there are advantages with the Mamba X / Revolver brushless outrunner combo in my Bomber...
I can run 4S if I want, and I have the Aux Wire function on my 3rd channel serving to change the mode from Rock Racer to Rock Crawler, turns the drag brake on and off.
Hey JRH, berg comp rig, br-mini's, with team puller 13t xx wire 500's motors powered by a nano-tech 450mah 3s 65-130c battery.
Out of curiosity I'm sure you'd know how many amps do the puller motors draw continuously and burst/torque stall?
Br-mini specs on website are 30a continuous, 80a burst
Just wondering about the demand the puller motors want.
JRH, question ???
16t handwound crawlmaster on a 1080 vs a 1800 revolver on a SW4.
Which will have the smoothest startup on a 7# rig running 3s?
Hang up and Drive
Crawmaster should, but I haven’t fully tested the 1080 startup sensitivity with one . . Although the revolver and sw4 is so close to a crawlmaster that most situations would be perceived as near equal startup.
I’ve gotten a little wheel time with one now. They aren’t too bad, but I haven’t tested with the crawlmaster to really see low end resolution.
JRH - will the recently added DRAG BRAKE RAMPING feature for Mamba-X become a feature for your BLE series ESC's as well? I'm loving the feature now with my Mamba-X and 1800kv Revolver. I'd love to use this feature for my Truggy that's using the BLE ESC and 3500kv PP Stubby.
What is the difference between copper and silver 'stand up' brushes?
Should I have a pair on standby? Or, how long does a set generally last in a Torquemaster Expert? And how do we tell when they need to be replaced?
Is there other maintenance required on these motors?
John, quick question about the blh servo issues...
I had you send one to me in the UK a few months ago. Due to working away a month at a time I've used my new trx4 truck and servo only a handful of times and I've actually changed the radio gear as well.
How recent was the batch with the issue? I ask because the first time I used the truck with the traxxas radio after a firmware update the servo was acting crazy at random points. I then updated the firmware and it seemed ok. I have since changed the radio gear completely to a different make and it still seems ok in the couple of times I've used that. I'm assuming mine is ok but just wondered if you had seen any that started working after they showed some signs of problems at first.
Cheers
John, please see post 1008. I got skipped over yet again in this thread. Thanks.
Ben
John,
Few questions. I’ve got a crawlmaster pro 13turn. What does that equal roughly to a regular 540 motor speed wise? I’ve got a custom build that I’m taking the gear down volt up motto to the max. I’m at 96:1 total reduction. I ran it with one of your trailmaster sport 550 can 27 turn on 3s with a 1080 esc. The low end smoothness was great and top end was slow to be expected. About a slow walking pace wide open.
I just bought a brxl and want to go 4s power. I have three of your motors on hand. 13t crawlmaster pro 540, trailmaster sport 27t and 45t, both 550’s. If gearing is kept the same, which motor will have the smoothest start up and top speed a little more than my current combo. I can change pinion if needed but figured I’d keep that constant to see which motor I like the best. Right now I’m at 15t pinion and 86t spur. I don’t NEED the 550 power as it’s a leaf sprung scaler around 9-10 lbs but I had them on hand and figure there’s no replacement for displacement.
Thank you.
Ben
tapped-out’s post pretty well covered your question.
Indeed. None of us have used his products, or had first-hand experience with them. We're just bored "keyboard warriors" stumbled across this site and decided to take a stab at answering random questions.
