Hardcoretam
If you have a brushed 540 electric motor that's 35 turns and you have another motor, of the same design but it's 45t with advanced timing to give it similar wheel speed to the 35t (say 12 degrees?) what will the pros / cons of each be in terms of
Battery life
Torque
Start up
Heat generated
Total power
Brush life
Comm life
Also, is 12 degrees advanced timing on the above situation likely to give enough extra rpm to get to a similar kv to the 35t?
Battery life
Torque
Start up
Heat generated
Total power
Brush life
Comm life
