Chassis kit question
cul8tr
Hickory,NC
Will the Element Senduro transmission work with the Vanquish battery tray? Or should I stick with the Axial trans?
Pondering next build;
Vanquish chassis kit
Element trans
AR44 axles
Element trans
AR44 axles
I believe it to be the identical mount pattern...
I have a set of AR60's also. Thought about that to."thumbsup"
I know that the mounting holes are the same for both trans but just wanted to know if the battery tray and element trans will have the clearance for a 3s lipo in the tray.
Overdrive gears are $40ish and the Element trans is $50. I can spend $10 more and have a complete trans.
The Enduro kit tranny comes with the plastic overdrive gears. Or maybe you're comparing to overdrive gears for the Axial axle.
Yes on comparing the overdrive.
Since I need a trans and if there is enough clearance for a 3s lipo in the tray I'll go that route.
Thank you for that link. Dang that trans and motor are high.
Could it be possible to tilt the trans to the motor side by shaving some material off?
It would be sweet if there was a laydown trans/gearbox like in the 1/10 buggies.
Ok sweet! Just let us know.
I just got the chassis and put it together. Waiting to decide on trans/gearbox that I will use.
Element trans
AR44 axles
Killer!
(I'd only change it to SSD SCX10 II Diamond Pro axle housings) ;-)
