Question about torque twist???
Frank211
Surprise
Does the motor affect torque twist(the way it's facing)?
The right front tire is the one to left up on torque twist, correct?
Again, thanks to y'all for the help/understanding !
the motor will have some affect but mostly its the direction of the motor that decides what side of the wheel lifts also link geomitry can have some afect on tire lift aswell so say for exsample ar60 axles you can flip the ring gear and reverse the motor and the opisite side will lift or not lift depending on suspention geomitry
Torque twist is a function of drive shaft rotation & torque reaction due to gear reduction in the axle.
Motor location can minimise some of it's effect by placing mass on the chassis over the tire thats trying to lift,
Likewise with an axle with offset pumpkin, moving the pumpkin to the side trying to lift can use its mass to try counter the twist
other wise the rotational direction or way the motor is facing has zero effect on torque twist.
Which side lifts is determined solely by which side of the rear diff the ring gear is on & hence which way the rear drive shaft turns, ring gear on left, left front lifts
ha ha ya thats what i was trying to say but suspention geomitry plays a part as well and the front axle will twist too its realy noticalbe when running rear sway bars
