Hi all, I have a wraith that has been sitting for a couple years now. I decided to clean it up, and swap the stripped transmission gears that downed it years back.
I noticed that when I turn it on, the wheels lock to the right and the steering servo motor is loading up and keeping it in place. The throttle doesn’t work during this either. If I unplug the servo, the throttle works fine in both directions as well as the drag brake. If I plug the servo into the port the throttle is connected to, I can get the wheels to turn left and right with the throttle trigger. I threw a new factory TR325 receiver and a new battery in it and the same thing happens.
I’m kind of leaning towards the EX-2 esc to be faulty at this point. It’s kind of my last option, what do you think?
I also swapped a new Savox SA1230sg into it after the fact for upgrades. Will I need anything different to help power this? Like a BEC?
Thanks!
Thanks!
