Natedog
Well that was a quick backup just in case servo purchase, not particularly hopeful that it's not junk. Searching for a quality stronger servo instead, any other suggestions?
Factory usb charger is still working albeit slowly, but I bought the plugs with leads that B-MOW71 recommended in his thread, made adapter for my Hitec X2 etc. battery balance charged in about 15 minutes. My ESC and motor have remained cool to touch even after 40 minutes crawling.
Crawler in a (shoe)box literally everything in one box. Bought Altra zero drop running shoes before PLBTF couple years ago (they are sponsors and have a run/crawl yearly competition.) https://www.altrarunning.com/
Ordered couple spare lipos, replaced rollcage lightbar with 3d printed straight tube (thanks Casey! userid HumboldtEF), using ABS-like Photopolymer Resin from Elegoo, not sure I like the print material though, needs to cure with UV rays (sunlight or UV lamp works) but when drilling the holes out before assembly, it kinda comes out chalky like shavings. Nylon would be better it seems. I hand-made this part out of SCX10 black plastic parts sprue the other night, it was sweet and perfect 0.125" diameter! Then I drilled screw holes too small and it twisted the end off during assembly even though I lubed the screw with Chapstick.
AX80018 parts: http://www.axialracing.com/products/ax80018
https://www.thingiverse.com/HumboldtEF/designs
