The 2290 is a beast, but this one appears to be waterproof. This one also appears to accept more voltage and it gives you more power! :shock:
Good find! "thumbsup"
Damn... 10.5amps at 8.4v at stall. If you were at stall for very long you could melt your servo plug. They are only rated for a few amps continuous. Honestly at that power level they should have just made the servo take pack voltages like HH's servo does. To run that properly you need a hella beefy BEC, even our normal CCBEC can't keep up with that. You would need a BEC Pro or BEC 2.0 just to power that thing.
Wow, 900 oz-in? :shock:
Kinda overkill ain't it?
For what?? Lifting people??:shock:Nope, I wish it was stronger sometimes.
So lets's exaggerate the servo arm to be 2 inches. That means the servo can lift/push 450 oz. That's 28 POUNDS! :shock: Of course that's exaggerating the servo arm to be 2 inches. Anything less will only make that 28 pounds larger.
We really need more than that for our 1/10 purposes?![]()
900 ounce inches is 56.25 pound inches. these specs cant be compared directly to poundsSo lets's exaggerate the servo arm to be 2 inches. That means the servo can lift/push 450 oz. That's 28 POUNDS! :shock: Of course that's exaggerating the servo arm to be 2 inches. Anything less will only make that 28 pounds larger.
For turning the tires from side to side. Not all of us drive small obstacles on flat ground. I've used the power of a 2290 to free my rig from a crevasse by tossing the rig after a few left & right wiggles.
