Benp
Wait, so what's a paralell charging board for?
Because I only need to charge at most 2 at a time
If by adapter you mean, for ex.,Deans plug to xt60 , then yes you can. That’s how I have to do it because my one battery came with deans plug.
The parallel board is for charging multiple batteries off one channel. So for the Hota, you’d get one of the Safe para boards that king meow linked, switch the main lead to xt60 and then put your adapters on the xt60 charging plugs on the board. Plug your batteries onto those and then charge.
I think. This is still kind of brand new to me.
Here's a picture of my overall charging case. I used a Harbor Freight tool case. As you can see, the server power supply is in the back that feeds both channels. It's not too sexy, looking like a tin box.Note the $5 smoke detector for safety from Home Depot.
All the cables tuck into the case for storing and the parallel board goes in too.
Here's a unit that I isolated the ground as my original intention was to combine two units for 24V output. You cannot connect the two units' ground or you risk an electrical shock. I added the label to remind myself.
It became too unwieldy when I tried adding a second supply and made it heavy and not too portable so I just used one supply. So far so good.
BTW, I check the label on the unit and it says 502 watt output at 12 volts. So the math says 41.8 amps! "thumbsup" I added the parallel board in the picture for a size reference.
This is a close up of soldering the correct jumpers and soldering on the terminals so you can use banana jacks for the charging leads or cables.
BTW, the power supplies cost me nothing. My work was throwing them out by the boat load even though they were perfectly fine and working. Server power supplies have a life expectancy rating (3 years in this case). When the time is up, you are required to replace them all with new ones to guarantee 99.9% up time, even if they are working. Don't want to tell the boss you tried to save a few dollars and the whole company shuts down.![]()
That is Awesome!!!!! Way to repurpose!!!
I hope you scarfed up a lifetime of “trash” power supplies. [emoji16][emoji106]
You could probably make some cash building charging setups like that!
