class 1 venture build
straight6zj
ocean county
so i just pickled up a few upgrades for the venture i just picked up
reefs t5
hobbywing 1080
castle bec
lcg battery mount
metal links
rc4wd arb diff covers
rc4wd xvd universals
brass axle weights
strc brass c hubs
strc brass front lower shock mounts
strc brass steering knuckles
strc brass rear lockouts
and strc brass rear lower shock mounts
it will be on 4.19 klrs
have not decided on a motor yet still up in the air any suggestions
also waiting for bowhouse high clearance skid to be in stock
You've got quite the list there. Not sure what your running for a body, but unless its super heavy you probably dont need that much brass.
Im running a Holmes puller 2700 stubby on 2s. It creeps along quite well, and tops out about 6mph, which is plenty for a c1.
unfortunatly by me i cant run brushless in c1 its a brushed only comp locally im prolly gonna grabv a hh motor just not sure wich one yet
and yes it is alot of brass i will probly only use the c hubs and knuckes i just bought everything to have it lol i have a problem doing that ill see how it does with just hubs n knuckles
Nice parts list, that should work. "thumbsup"
That's an odd rule for C1, not sure why a motor type would make any difference. I run both types in various rigs and set them up to be pretty close to each other in performance. Anyway, I have become fond of the 1080 and Brood 35t combo myself. I run that setup in my C1 Venture and love it, nice smooth low end with plenty of wheel speed when needed with a 16t pinion.
https://www.amainhobbies.com/team-b...shed-motor-35t-bro-tbr-intensity35v2/p1224245
awesome for 30 bux cant go wrong im ordering one now as well as a 16t pinion not sure what stock is havent taken stock motor out yet i gotta post up pics once i get everything on thanks for the info!!
"thumbsup" Stock pinion should be 16t. Note: I also run 50-75c 3cell lipos in 1350 to 2200mha range. My C2 and 3 rigs run the smaller 1350 and 1550 packs and my C1 runs the 2200 because I have room in the bed.
Should be a nice build, I'm not a fan of the Ref servos personally but they seem to get a lot of love.
The only thing I found on my Venture that kept me out of C1 is that you need really narrow wheel hexes (3mm? Smaller?) or low offset (or is it high offset, I can never remember which way it goes) rims to get total tire tuck under fenders. Other than that she's pretty well perfectly set up for C1..
I run the narrow Axial hexes and Loops fender flares on my LC body, pretty much have full tire coverage.
So just got some news the brass c hubs and brass knuckles are back ordered till December so the build will be put on hold.I may purchase that killer tf2 on for sale forums so I dont get bored I’ll build that up lol while I wait for parts but then that would b my class 1 or maybe I’ll do trail rig Instead hmm
RPP hobbies show they have the brass C-hubs in stock. They also have the brass diff cover as well. No brass steering knuckles though. These parts are getting hard to find since I’m not sure HPI makes the vehicle any more.
Honestly that seems like a ton of brass for a c1 truck going by your list. I built the SBK and only used the brass weights they included in the kit. I am running the Rc4wd bumpers for the FJ body and it performs great. I know some weight is needed here and there, but with the front mounted motor and metal bumper mine already has a ton of weight forward bias.
As for motor, I am running a Holmes crawlmaster Sport 540 16T with a Hobbywing 1080. Great low end control and plenty of wheel speed if wanted. I know Holmes is out of those motors currently though, but something similar would do great depending on what your looking for in power wise.
thanks and i dont plan on using all the brass i just grabbed it since its usually not available. not sure what i will use as far as bras i will try a few diff options and as far as motor i am going with a hh crawlmaster expert 16t since the sports were sold out
May I ask where you picked up the brass knuckles?
I have searched and searched for both SSD and STRC brass knuckles with no luck. SSD is not producing anymore (I confirmed with them.)
reefs t5
hobbywing 1080
castle bec
lcg battery mount
metal links
brass axle weights
strc brass c hubs
hey sorry havent been on site in a while i luckily grabbed my set off rpp hobby i cant seem to find any more parts anywhere for the venture either i hope they bounce back and revive the venture its a great rig imo i prefer it over alot of my rigs
