Traxxus TRX-6 Upgrades?
ravencr
Maryville
Traxxas TRX-6 Upgrades?
Hey guys,
I’ve been out of this sport for a while, but we got my son 5the 6x6 G-wagon, and he’s loving it. Anybody else have it and recommend certain upgrades to make it mode capable while crawling? I thought I saw somebody makes brass portal weights, maybe wheel or axle weights? I’m not sure what else it needs other than some body trimming at this point. Any good feedback would be appreciated.
Chris
I put these on my trx6. Had to wait for them on the slow boat but it was worth the weight for the savings to get these parts together. Throw em all on the front axle.
As far as the rest of the compatibility goes, mostly anything for the trx4 will work on the trx6 with the exception of the middle axle of the trx6, that’s all unique to the 6x6.
https://www.ebay.com/itm/RC-TRX4-Br...709646?hash=item48ea21814e:g:R2IAAOSwPLNdY7ek
TRX-6 is already capable in stock form. Brass portal axle covers would be a start. A 2s shorty lipo in the front for more front weight bias. A servo winch. Stock tires are great (maybe swap out with super swampers or hyrax?).
I have never heard of "Traxxus" but if you read through the Traxxas TRX4 section, there are litterally thousands of posts on TRX4/6 upgrades.
these are so good out of the box, the first change would be the red steering servo and metal servo horn. The stock servo can't do much if the weight of the truck is all on the front wheels.
Just want to clarify this, the middle axle is the same as the "4" but instead of a standard diff cover it has a pass through cover and a second pinion.
The rear axle however, if unique as its link mounts are entirely new to allow correct geometry of the rear axle.
(Unless there's something I'm missing. If so, I apologise, ignore me)
Sent from my LM-V600 using Tapatalk
One day, finances permitting, it'll be a Power Wagon wrapped in one of PimpinRocks' art pieces. I know, super original idea. I want it to resemble something between the Race Tractor and the Huak Designs Wrecker. I cut that stainless plate for a flatbed/minor cage work idea I had. But between lack of proper tools and tack or patience, I'm not at a point where I can be building cages.
Very nice, I tend to drive a little hard :lmao: I like making bodies and then immediately crashing/rolling them.
I had been planning on doing a full WW2 power wagon with my 6x6 and towing my silly trailer with it. But now I'm going to do a Power Wagon troop transporter on a 4x4. A 6x6 Dakar truck is my current inspiration for my 6x6, I have a unimog cab.
Sorry guys, never saw any reply notifications to my email. Anybody found good replacement driveshafts for these TRX-6's, because these were garbage: https://www.amazon.com/gp/product/B08LCXC8VR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1...broke first battery.
Chris
If you're still planning on adding weight to your "6", I'd recommend sticking to the OEM drive shafts. They're durable enough (in my experience) you shouldn't have to worry much about them breaking.
But if you go too far, the OEM plastic shafts should act as a built-in failure point that's easy to replace. Assuming there's no other week spots in your truck anyway.
Only thing I added to mine was brass weights up front. I'm still running stock everything and have had the truck since release day. The truck is super capable out of the box and out crawls/climbs/descends all my other 4x4s in most instances.
