So what is the procedure for updating the ESC?
Lou
This is all I've seen on the subject:
Lou
Nope, that step is to remove the write protect on the original BLHeli_32 and put the AM32 in
So I’ve ordered the Serial programmer from Holmes. If all goes to plan, my C2 rig will soon be 4s powered with the 1800kv snubnose…
Lou
Hang on with the 4S, JRH has said no 4S until the V2 firmware is out. I think its only on V1.1
I have a Crawlmaster Mini but also tried to make my own out of an Airbot Wraith32 V2 ESC (per Voodoobrew's thread and Alka's tutorial). I'm getting stuck at the part where I program it via ST-Link because it won't let me update the firmware of the Link. I've tried the Utility Tool as well as the STM32 Cube software. Do you think it's just a bad ST-Link?Nope, that step is to remove the write protect on the original BLHeli_32 and put the AM32 in
Instead, go to the second post by Voodobrew and go to the AM32 config tool section. For the config tool, you should use the one in the Holmes zip that you dowload from holmes website (it looks the same though), the folder named ESC_Config_Tool_1_68_Win. When you run the exe file it actually says ver 1.70 Holmes Crawling Edition.
Follow the steps described by voodobrew's post to connect, and then go to "Flash" tab to flash the new firmware.
I have succesfullly update my fw to v1.1 by using the arduino nano with the steps described above, but I still cant upgrade to the v1.2 (the process completed but my esc failed to start up, so I wnt back to v1.1)
With the new firmware V1.2 its ok"thumbsup"
I think it would get better respons if you post this in the voodoobrew's thread. I don't know for sure, it could be the problem with your ST-Link. But I don't think you can flash Holmes firmware to your Wraith32. It's different hardware.I have a Crawlmaster Mini but also tried to make my own out of an Airbot Wraith32 V2 ESC (per Voodoobrew's thread and Alka's tutorial). I'm getting stuck at the part where I program it via ST-Link because it won't let me update the firmware of the Link. I've tried the Utility Tool as well as the STM32 Cube software. Do you think it's just a bad ST-Link?
I'm willing to buy another ST-Link if I'll be able to flash the Holmes firmware onto my Airbot Wraith32 V2 ESC. This is the first I've heard of that compatibility. Can you confirm that? Thanks![]()
Sent from my SM-G960U using Tapatalk
I thought I saw on IG that the 1.2 would allow 4s so we’ll see…
Lou
Thanks
In one of his live streams he mentioned once V2 is out 4S would be fine but maybe he had meant V1.2? or I might have misheard him.
Exactly"thumbsup"But I don't think you can flash Holmes firmware to your Wraith32. It's different hardware.
Just curious if there's any ETA on when these will be back in stock? And is there any way of getting a non RTR version? Thinking about running two w/ one battery connector for a MOA setup.
You can sign up to be notified when they're in stock, though with products like these that are in high demand that email will come too late. Checking facebook is probably the best method, he's been calling out what days they'll re-stock some of these newer items.
I think the Non RTR version got pulled from their site shortly after the RTR version came out.
You could email them to see if they'll do a few of the non RTR's for you. They might even assemble a dual setup. If its feasible and they have inventory thats unassembled they'll probably help you out.
