TF2 Kit and AR44
xtreme4x2
WA state
Besides the JEC racing leaf mounts, what else would I need to swap AR44s on to a TF2 Kit?
I have spare ar44s and am looking at this TF2 kit
https://www.horizonhobby.com/produc...th-mojave-ii-body-set-white/RC4ZARTR0001.html
My 10.2 has leafs in the rear, but I know the TF2 has angled shock mounts. I'm assuming I wouldn't be able to use the AR44 shock mounts?
Any advice is appreciated. "thumbsup"
*edit* just watched a video with a guy using the ar44s but switching to a 4 link. I think I could get the ar44s to work with the leafs. Any tips are still welcomed!
AR44 axles with the JEC mounts bolt right up. In the rear I am currently not running shocks, and in the front I moved the front shock hoop on the chassis 1 hole bock. JEC makes a low profile shock mount for the rear.
The JEC mounts only work with the 3 piece AR44 axles.
Awewome! Thanks for the info!!
The JEC mounts also work with the SSD pro44 axles thats what I'm using on my 10.2 with leafs. Im pretty sure their diamond axles would too. I had a set on a different 10.2.
I'm thinking of getting the RC4WD 4runner and using the pro44 axles.. got some options now. Thanks again!
I am running the pro44 axles with offset tubes in the front. The JEC mounts will not work with the TrailKing tubes.
Thanks again for the info! I just ordered the 4runner and pre-ordered 2 set of the brass jec mounts "thumbsup"
