Schs2013
What you could do is move the battery tray forward (front half will be resting on the transfer case). The back holes of the tray will be mounted in the front holes.
Depending on the size of your battery, you could Velcro it to the slider.
Next step is try modifying the tray itself. Either cut off some of the walls of the tray, or move it more forward as much as you can and drill new holes in the tray to mount it.Tried your idea. Would still require alot of body and cage trimming.
Looks to me like the body needs to comeback on the chassis about 1/2" or so. I would line the peak of the wheel arches with the center of the tire personally...
That picture was taken at a angle. I did note the same thing. Here is with the tire on at full stuff. At a more of a straight picture. I think it is pretty centered. If anything i could just trim the body or deal with a little tire rub.https://uploads.tapatalk-cdn.com/20221018/b3e4695c97a2a72c8df8a26a75365166.jpg
Sent from my iPhone using Tapatalk[/QUOTE]
I still think the body needs to come back a bit...
I have a couple questions if you don't mind helping me out with the answers.
1: How accurate is the shape of this vaterra body to a 1:1 square body?
2: Could you take a shot straight on from the back to show how to cage lines up relative to the body lines?
I've been looking for a pre-built cage that'll fit in the back of an RC4WD Blazer. I know the RC4WD and the Vaterra are modeled after different years but Vaterra cage looks like it's about the shape I'm looking for. I might be able to make it fit if it's close enough.
Sent from my LM-V600 using Tapatalk
There's no specific dimensions, other than maybe width.When i get the truck body back i will attempt to awnser your questions.
I never been compared a 1:1 to a 1/10 scale. Not sure what dimensions you need?
