Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to RCCrawler Forums.
C frames are normally narrower at the ends (~70mm) than at the skid (~78mm). Am I supposed to bend carbon rails too? If I use wider frame spacers, the shocks get too close to the rails, almost touching.
It's going to depend entirely on the CF chassis kit. Some kits keep the rails straight, while others "pinch" them at the front & rear. Beast thing to do is built the frame as the developer designed - if the rails are meant to be straight, keep them straight...don't "pinch" them.
Using a couple of mine as examples, the GameChanger chassis from The Crawl Space uses a "pinched" design, whereas the Ground Fox chassis from Artful Dodgers uses a "straight" design. Again, however the kit you're building is designed (straight or pinched), I'd recommend keeping it as the designer designed. Just a 'suggestion'.
