Injora Tarantula VS Meus Ripper for the TRX4m
Fallen
Subscribed Member
San Marcos
My hope was to make some obvious distinctions between my twin sons' TRX4ms. So for one son I bought and installed the Injora Tarantula cage.
Once his brother saw it, he wanted a roll cage too. I looked around and found the Meus Ripper cage, and he liked the look of the headlights.
So now they look pretty similar again. But at least I can review both cages for you guys.
The Injora cage doesn't look as good to me. The Meus looks more like an Ultra 4 car while the Injora cage looks like a rock buggy. I just prefer the Ultra 4 look.
The instructions for the Meus Ripper are pretty poor. You pretty much have to figure it out yourself. The instructions for the Injora are very helpful.
Both cages work with all of the stock TRX4m components. Both cages needed holes cut in the hood panel to clear the steering servo. Both cages come with everything you need, including hardware to complete the build.
The Meus cage feels weaker than the Injora. Once I had the Meus cage put together, my first thought was "crap, now my son can't bash his TRX4m quite as hard." I never thought that with the Injora cage. Hopefully over time the Meus Ripper proves just as strong.
The Injora includes a lightbar. The Meus cage doesn't. But if you buy a lightbar for the Meus cage, you also get headlights.
These photos are completely stock TRX4ms, except for the cages. The Meus Ripper comes with an interior that I didn't install. The interior would have to be removed and reinstalled with every battery change, unless you modify it.
First up, the Injora Tarantula:
And now the Meus Ripper:
Good comparison. There is a meus horizontal servo mount for that chassis. I don't remember but i thought there was one in the kit.
I wasn't satisfied with the available articulation so modded mine by extending shock mounts.
Sent from my LG-V521 using Tapatalk
There was a horizontal servo mount included in the Meus kit. It looked like I needed to cut the old servo mounting tabs off of the axle, to make the horizontal mount work? Is that right? Once again, the Meus instructions don't answer many questions.
I was just worried about making any permanent mods to stock parts, when I hadn't tested out the Meus cage yet.
Thanks for the info i was looking at both of them and got the injora mini bomber cage
Not having a trx4m to start with I'm still waiting on parts and I really don't have a understanding of what's all going to the weres so it's nice to see one finished and it looks pretty good too
I have parts on order but damb these little guys are supposed to be cheaper to build damb it but there not so my build is gonna be another slow year long adventure lol
Update for the Meus Ripper:
My son has been abusing it just as he did with his Bronco body. It's been just as tough, and nothing has broken.
If you install the headlights into the Ripper cage, you'll want to add a drop or two of CA glue to hold them in. It's just a tension fit, that doesn't hold up under hard impacts and they fall out.
And fortunately for my wallet, I only have these TRX4ms for my 5 year olds. If I had one for me, it's would quickly be the same price as a 1/10 scale build. There's so many damn options for these things!
Both look great and thanks for the side by side comparison, I like the Meus Ripper look better but they are both nice! Meus does include the laydown/sideways servo mount and yes you have to cut half of the stock servo mount ears off the front axle housing to install it, easy to do and lower CG for sure. :)
Thanks for the servo mount info. I'll probably use it then, as my son killed his servo and we need to replace it. Now that we know the cage is strong, I don't mind making permanent mods to stock parts.
