Would it work; front or rear diff as a transmission?
Gula
Subscribed Member
Here
So here I'm thinking of using a traxxas summit lockable front or rear differential as a transmission that splits front to back power on a rally build. Its really big. Don't most bashers, old nitro trucks, etc have a similar gear ratio as a diff? This way the transmission is small, no pinion you have limited slip/awd, and a fully lockable 4x4? Would that work?
Another idea I had was using an arduino, some optical sensors, and disc brake system (losi promoto) to create a full on electronic "drivers assist" like some of the 250k 1:1 have. ABS, launch control, traction control, etc. I think the active suspension module from superscale2020 could even be integrated for track like performance.
Plausible?
This is beyond my level of RCing but the thought of it all sounds super fun. I like seeing those rally videos of people recording themselves following their rally car through a course.
Plausible?
the diff idea should work as long as your tires aren't to big the gearing would be like a 3 gear with no spur or pinion gear I have my d12 set up like that a outrunner direct drive to a 3 gear but it's only running 3 inch tall tires the 3.gear is about 3 to 1 and a diff is around 3 to 1 so the ratios are close
the gearing creates a spongy feeling on the throttle plenty of torque but it's not right there like most rigs
probably fine for a rally car the set up would in a way limit your off the line torque
the open center diff will help keep the front wheels on the ground if you still have to much torque off the line
with the right power system I'll bet it would be a vary forgiving vary drivable rally rig
I have absolutely no clue what the second part of your question is what your asking or what any of those components are or would do
in the 1to1 world launch control is basically just reving the engine and dumping the clutch so no you wouldn't get launch control that gearing will cause the opposite affect in my opinion
traction control is usually turned off when off road or trying to get any performance out of a awd system mechanical systems work best ie electric coolaid and or lockers
anti lock braking would be on the controller I would imagine the better your radio the better your anti lock breaking system would work lol
$250,000 race cars, that can bias power and torque to each wheel independently.
For example: a 1/8 nitro race buggy that has a disc brake at each end of the diff output. So 2 total, rach independently contollable via 2 servos to slow the unloading front end.
My explanation is probably clear as mud.
Ferp, this is for example in a 1/5 rally car. Each wheel has its own disc brake, each controlled via micro servo. The center diff would also have a disc brake and micro servo on each end.
Brake cables used throughout
If the micro servos aren't up to the task, then regular sized ones will do. Plus there are other ways to pull cables
Technically now you can apply the brakes power to any one wheel while having all others receiving different amounts of power, or be at a complete halt.
Each diff would have some sort if diff fluid. However, im unsure of the cst rating
Second part of the same project is applying a "ABS" ring gear, something similar to say like the Traxxas optidrive system in their transmission, going to each driveshaft. These 6 sensor would feed a small (arduino) computer, and it in turn would apply a signal to each servo to hit the brakes on a slipping wheel, or whatever.
I think this would give you mechanical ABS, stability control, traction control, launch control, yaw control and not sure what else.
Vw has something similar on their GTI and R where they apply the brakes on the inner wheel in a turn to pull the car through the turn.
I think you could do balls out driving with less of a chance of crashing.
Subaru has all those features to i have a rig with all that fancy stuff I hate it it never gets it right i had to undo all the sensors and go mechanical the computer just doesn't respond fast enuff and usually over responds causing jurking and pulling or outright loss of control you really have to overpower the steering wheel and ride it out not fun I have a friend who lost there roo from that
my daily driver is still mostly mechanical the computer still runs the abs system the center diff and the front and rear diffs run electric coolaid and it's the last year for the non computer controller trans and traction control
my oldest one had mechanical launch control it was kinda cool a spooled up rear and up front a manual traction aid controlled by a lever works great and and can be split for steering breakes in the middle a manual locking center diff also has front dig lol
anyway you guess which one handles the best off road
ok my point is unless you have 250k to create a computer system than can do what your thinking of doing for a rc car and have years to develop and test the system it probably won't work right seeing as how Subaru spent millions on there system and it still doesn't work right
