you can peice together a pretty good rig for about $200 if you take your time
would take some used take off parts and will take more time to build
If you want to use the axles onto the TRX4 or VP, you have to change the steering links. Material: aluminum alloy housing, steel shafts and gears. 1X Assembled Rear Axle. N.W.: Front 210g. 1X Assembled Front Axle.
www.ebay.com
Find many great new & used options and get the best deals for Transmission with Gear Replacement for Axial SCX10 Car Upgrade F4A3 at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Center skid plate for the Axial SCX10 RC crawler. This gives you a little more ground clearance to prevent getting hung up. You will also need long M3 grub screws for the lower links on the skid plate.
www.ebay.com
AXSPEED Steering Rod Link Linkage Set 313mm For 1:10 RC Crawler SCX10 II 90046. AXSPEED Aluminum Transmission Center Gearbox for 1/10 RC Axial SCX10 Car Crawler. AXSPEED 100mm 1.9" Rubber Tyre Tire for 1:10 RC Rock Crawler Axial SCX10 D90 etc.
www.ebay.com
if you look on alliX you can find these same parts alot cheaper these are just random items i found from a quick ebay search but you get the idea
your bigest exspense is the axles and the radio and tires everything else is in the $10-$20 range
tires can get crazy exspensive but used take offs and chinese off brands are cheap
bodys are the same way ive bought many for $20 and some up to $200
