  • RCSC
"Transing" the LOSI Promoto MX into Making MX Gr8 Again
Timmahh
Mudville
Figured it was a good time to post up a short semi build thread on the new Supermoto build.
Didn't take as many pics as I should have, but got a long ass youboob video of the build so...
Figured I may as well put it on 'internet paper' for some documenting and sharing of the build.
Started out with my Original Promoto MX I ordered when they first came out, then went on back order.
This was the Pro Circuit (Green) version. With things as they are (were) when I started this out, I was hoping to have it ready by early spring, but life got busy and time got thin so it sat around most the summer pretty much done, but not finished till the last few weeks really once I got the Grafix figured out and ordered along with the outfit for the rider.
HM Moto Designs also did this rider gera and grafix design and print. Dylan also did the MAICO MEGA2 490 Promoto MX I have a thread on also.
Not hard to describe really. Black and Gold was the goal, So I ordered a shizload of Treal Promoto upgrades and got to work.
I'll try to list the build list from Memory, and I still have a few things that I want to finish up on it.
Pro Circuit Promoto MX
Black Plastic Set
Rear End
Treal Adj. Swing Arm in Gold
LOSI Titaminum Hinge Pins for Swing Arm Knuckle
Treal Chain Guard in Black.
Treal 36t Sprocket in Gold
Treal Rear Brake Caliper and Disc in Black
LOSI Titanium Rear Axle
Treal Carbon Fiber Rear Rim in Gold
Treal Rear Hub in Black
Vitavon SuperMoto Rear Tire
Hot Racing Exhause Pipe
Treal MonoShock Top & Bottom Shock Body Caps
Green Slime on the Orings
Chassis
Extreme Carbon carbon fiber chassis plates
Treal Fly Wheel Box in Gold (hidden so you don't see it).
(I did this to add weight down low to help lower cog a bit)
Treal Skids in Gold
Treal Foot Pegs in Black
Treal Gear Box Cover in Gold
Hot Racing Bearing Holders for Gearing on Transmission in Raw Aluminum
Treal Front Brake Mount in Black
Reefs SMART 179 Micro Servo for Front Caliper
GPM Brake Servo Arm in Gold
Front End
Treal Tripple Tree in Black
2Million Diff Fluid with a little 500k Diff Fluid mixed in
(LOSI uses diff fluid in the Goose Neck of the bike to dampen and reduce head shake to some extent,
but it can still get pretty floppy from time to time.
Stock was 500k, and being I was aiming for onroad, with more forces due to traction, more dampening
would be needed, so I used some 2 million. I had 10 and 20 Million diff fluid but that seems like it was
too much.
LOSI Shock Oil in the Front Forks
(Stock is 45w, but I think I went down to 32.5w oil to soak up the braking into corners from speed).
Treal Caliper in Gold
Treal Lugs in Gold on
LOSI Titanium Fork Lugs
LOSI Titanium Front Axle
Treal Front Carbon Fiber Rim in Gold
Treal Front Hub in Black
Vitavon Supermoto Front Wheel
Treal Titanium Front Brake Disc
Treal Front Disc Brake Pads
Red Front Fender (Red Tie)
Bike was put together using the new Fast Eddy Bearing Kit for the Promoto.
Amaxzon American Desk Flag which was something someone was carrying around the Capitol Building on J6, 2020, besides Podium Guy (lol)
I have a Reefs 299LP in Black to install yet, and a CC Mini BEC to put on the front Brake until I do the steering servo Swap.
The stock steering servo works fine, so I didn't swap it over during the build. So, I got the CC Mini BEC allowing full power to the Reefs 179 to get maximum braking power out of it.
The stock ESC BEC is set at 6v and might adjust to 7.2v, but I can't remember at the moment.
The CC Mini BEC is a fixed 8.4v output.
On to the rest of the Pic Porn, and I'll post the vid in a follow-up comment.
Ready To Save America from the Radical Kamalunist!
READY
CHARGE###############
Graphix by HM Moto Designs. Dylan does 1:1 Moto Grafix packages and added the Promoto when it was released.
Rider Gear
Let's Roll
When the build was ready in May or so.
Weather's went to shit. I was hoping to get some vid but been pretty busy. Next time it looks like it'll be sunny out, I'll bring it to work and try to get some running vid.
iu
Ordered a set of Gold GPM Fork Tubes. The stock gold is quite different looking and wanted to match things up a bit better.
These will do a fine job of that, and they are also 7075 so should hold up better over the long run also.
Timmahh that bike looks dope and your theme is more than hilarious ... I would be afraid to use it though its probably worth more in aluminum pieces than my carbon bitted 1:1 Speed Triple. :love: yours truly amazing though and the best theme built.
Thanks Speedy-T. It was a fun build, just wish I had got to ordering the riders gear and stickers in early summer. Could have had a bunch of video by now. But in Michigan I'm 1/2 stuck till spring basically before I can get any decent vid, unless I can run it inside a mall or something. lol
Installed the GPM fork tubes tonight while watching some TimcastIRL.
Looks much better than the stock LOSI Gold tubes in the bottom pic.
Do you plan on running it? If so, I'm anxious to hear your thoughts on it. I had one of these bikes pre-ordered and then Horizon did what they do best and effed around and delayed the release so I cancelled. I honestly don't regret it because what I've seen from running videos, it looks like a typical, floppy RC motorcycle. Wondering what your thoughts are though.
I have about 4 maybe 5 packs through it so far. All onroad while at work. They can be a lil floppy coming out of a slow corner/turn, but much of that can be remedied. They have 500k diff fluid as a dampening fluid in the goose neck, I stuff in some 2 million and a good glob of 500k just to thin it a bit. Get very little head wobble but there is some once in a bit.
My MAICO bike has 3 dozen packs through it (didn't get no where near enough time to run over the summer). Jumping, dirt oval, racing at the Sand Pit rc track etc. Overall they handle great. Way better than my old Duratrax DX450 I still have and can run.
There are some good race vids on youboob from the guys in N and S cali area, a few others, and Chris Heartel from Australia has a fair bit of running vids. They are far more stable than the older dirt bikes.
LOSI did a pretty good job and other than a sticky front brake caliper they're pretty durable. Some broken rims/spokes and broken crash structures which is what they are designed to do, not many people have had many major issues.
Biggest electronic issue has been Stator on Gyro burning out for the most part.
Biggest learning curve is when to stop turning so you can exit the direction you intend.
Run it like a real bike, Slow down into the corners, make the turn and burn out of them. Roosts for days. lol
