The Wheely King Tranny has 4 gears inside:
1. located on the spur gear shaft is a 15 tooth gear (small end of tranny)
2 & 3. Located in the center on the center shaft both are 22 tooth and are separated with a spring this being the slipper gears (I did not disassemble these to look at them any closer) but this is where the clicking comes from when in a hard bind.
4. located on the out drives shaft is a 28 tooth gear
Below are some pics:
Note; only three gears are visible as the center gear has another directly beneath separated by the spring
PIC 1. gear location
PIC 2. cover w/ bearings
PIC 3. gears 2 & 3 with spring / slipper
I hope this helps better understand the WK tranny."thumbsup"
