battery charging help
Specs say 2.5 amp charge rate. A 2500 mah battery charging at 2.5 amps will take about an hour. A 3600 mah battery charging at 3.6 amps will take about an hour...
You'll need to keep restarting the timer, until the battery is warm to the touch.
If this is the battery's first charge you should let the timer expire, and let the trickle charge run for about 10 hours.
well im the second owner when i got it it had 1 charge on it. so i should just keep restarting the charger till the battery is warm? .....maybe thats why i was only getting 15 min runs i was only charging it 15 minutes. thanks EeePee.
yea its on the list lol. Right now i'd rather spend that $ on better rod ends.
alright thanks man. Yea i been charging the batt for 15 mins maybe that why it doesnt last long.:-( thanks again man"thumbsup"
it will probably take an 1 hour and 30 mins to get that thing worm!:lol:
