shierkahn
Thanks jOe. Picked them up last night and started on the WB, almost done with that part of the build.
the round tubing in the article says 3031 1/4 .049 round tubing for the links but k&s website shows the 3031 1/4 round tubing is .035 wall, is this what they used and is it just a typo? I dont want the tubing to be too small to fit the allthread through because I have to mail order all this. thanks
I got the 82008 shafts from the e-savage for the crawler build on the WK but the 82009 shaft is back ordered. Is there any reason I can't shorten one of the 82008 shafts to use instead of waiting for the 82009 part number shaft to show up?
You're absolutely correct, just shorten the 82008 shafts, and save yourself the money. I'm a little miffed that I blindly ordered the unneccessary 82009 shaft, but I'm a newb and didn't know any better at the time. When my items arrived from Tower I was trying to figure out why I had just ordered 3 shafts. I suppose since this is an HPI build, and they're HPI parts they're going to suggest you order as much as possible:roll:I got the 82008 shafts from the e-savage for the crawler build on the WK but the 82009 shaft is back ordered. Is there any reason I can't shorten one of the 82008 shafts to use instead of waiting for the 82009 part number shaft to show up?
anyone else have problems with the rear drive shaft sticking? I cut the 13mm off and for what ever reason it wasn't enough... or the thing is sticking and won't collapse enough for me to put my rear links back on.
( I imagine the reason why they tell you to order the front drive shaft is so you won't have to cut two...)
