quick fix for the drive shaft
Thanks like to see the photos..."thumbsup"Let me know if you know of any other mods. Have you done anything to your shocks?
i changed them to excelorator shocks with 50 weight, one sec on the pics
before
plus move upper links to the first hole!! less bind straighter pinion angles
drive shaft swap
now the small end that is splined is going to take all the beating that the other end was able to withstand,and how will it slip after a days crawling ,not very well i suspect.. i think ill just add a metal ring instead of a zap strap....?
If you want to make your drive shaft stronger,you'd be better off adding female section. You only need about 1/4" of slip in your shaft anyway. Add a section of female so your shaft looks like this.....
rock sliders
Beau, what did you use for the rock sliders? seen best in the after picture mounted on the chassis between the two lower link mounts. they look like they work great
thanks
Im still not sure I understand the point of this fix. My shafts kept falling off the tranny outdrive but I put a spring inside the driveshafts and they havent fallen off or comem loose again.
Sliders are cool on your chassis and the tranny relocation is sweet. Nice work.
I fixed the front driveline with an emaxx drive shaft! Installed the same way you do for a Bender chassis TLT. I have had them on my TLT for almost two years with no failure.
Haven't figured out the rear yet, the emaxx shaft is to wide and won't clear the gear.
there you go. that looks pretty strong. I gotta try that.
