#17 C2 Zuul aka Zuullet (non SORRCA)
Goro Majima
Subscribed Member
NorCal
[POST 1 OF 2]
#17 in my crawler list was a different rig but since I have less than a week to finish my local comp build, this GSpeed FS V2 build takes the spot instead. Our local comp only abides by the rectangle rules for SORRCA Class 2, and being that I got a little taste of how fun a comp run is I decided to start a build for it. Although I could've made an existing build work, I didn't want to tear apart a complete rig.
This is a mullet build, utilizing a Chanquish F10T front and an AR45p rear. As I didn't own a Zuul body'd rig yet, the shape of it is perfect to work with, it's a really nice mold and most importantly to go along with my collection, it's a Toyota lol.
Build list:
- Element Zuul clear body
- GSpeed FS V2 black CF kit
- Hardcore RC AR45p titanium link kit
- Amzn F10T black front axle
- Vanquish F10 BTA mount
- Axial AR45p rear axle
- Dlux Ultra-light NOD transmission
- Dlux S2 ESC
- Dlux Stumpy 2200kv outrunner motor
- Amzn transfer case
- TGH modular titanium bumper
- Traxxas GTS shocks/mini T spring combo
- Treal Vintage style beadlock wheels
- Pro-Line BFG Krawlers vented (predator)
- Exocaged RC Pro Code inserts (soft outer F/medium outer R)
I'm not the biggest fan of how forward skid rigs look, but it'll be fun with the comp.
Side notes:
- Rails are flip flopped on purpose
- LP servo to be used
- Suspension zip tied down for tuning in droop setting but will install softer springs
- Sliders to be swapped out for comp spec sliders (I'll just make sheet metal ones)
- Front and rear ends of rails will be chopped off for comp spec
- Micro servo winch or DSM setup
- Paint/graphics undecided
Rear axle pitched back for driveshaft clearance.
The transmission is mounted forward on the skid, with the motor just clearing the servo under full droop.
As stated above, this servo/horn isn't staying. But with it in place, I was able to install the further bent drag link and have the clearance for full lock during left turns.
Look how much the servo hangs down haha. Even with a low profile servo, it's still gonna be well exposed but it's ok. Just seeing a F10T style axle with a BTA mount comping is cool to me.
[POST 2 OF 2]
ESC placement fits just under the short transfer case shaft.
Body resting on the chassis although not correct placement as it's not level.
Here you could see the lines where I will cut the body to lower it. The lateral line will be at legal limit (4.5"), and the fender flares will get trimmed off.
Here is a rough placement of how the body will sit, again still not level with the chassis but body scooted back to legal limit (front of body aligned with front edge of wheel rim). This is why the chassis rails will get the ends cut off.
And that's how much shorter the bed will be once I bob it and lines up with the rear edge of the wheel rim.
Can't wait to cut the body up and further tune the chassis. I'll try to update this build daily for the rest of the week as the comp is Sunday.
That's the first FS V2 ive seen. Lookin good. Forward skid sure is nice when it comes to breakover. Definitely gets hung up less on our terrain.
Looks like an excellent performance build. Gotta agree on the f10t axle, its pretty sweet. (My lusty side really wants to grab a set of those while they are around).
Curious to see how high you slice up that Zuul
[Update 1]
- Front flares trimmed off (original arch shape for now)
- Sides trimmed and ready for sliders to be shaped, hopefully complete sliders tonight
- Bed bob will be after paint
- Paint prep tonight also
- Rail ends chopped off
- Body is mounted in front only for now but levelled (side cut line level with rails but also meets 4.25" center rectangle/cab height criteria for Class 2)
If I wanted to be super competitive, I could lower the rear of the body and trim more off the bottom bed to maximize legal rear rectangle criteria, but it would also take away the actual shape of the truck and I'd rather have that.
Since I have the body mounted, the front end can mostly stay intact which is what I was hoping for. I want that FJ40 front on still and looks like I can mount the bumper without disrupting the Zuul headlight/grill piece which is awesome. Under full lock though, the corners rub so I'm gonna trim away that unfortunately.
Man Mr. Goro, the Zuul body looks great on there! I've yet to find a home for my spare Zuul body. I wasn't wanting to chop it up, but your body trimming looks great.
Can't wait to hear how the rig did on the rocks!
Small update before today's comp.
Previously drilled 2 holes in front of the body post holes to use clip tethers but it didn't look good. With 2 useless holes I had to do something about it. Turn it into 4 useless holes! 4 distinct ones that is. (TRD MK4 Supra style hood)
Before doing brass knuckles, let's remove weight before adding weight. Most Treal wheels come heavy, loaded with iron inner rings. Here's the difference in grams between the iron rings and the aluminum rings that were bought separately. With this difference off the rear wheels, I'm hoping it's enough to satisfy my needs and I don't have to totally disrupt the balance it already has.
Looks great. Not sure how I've overlooked this thread before now.
I've thought about doing a mullet with my zoku phoenix. Only thing holding me back is the amount of overdrive it would have on top of the vrd carbon trans. Figured i can use underdrive diff gears in front and overdrive in the rear and get the ratios close enough to work. Just another $80 or so in gears to get that done, so it's staying straight for the moment.
With my F10T front, Dlux NOD transmission (no overdrive), and AR45p rear, the OD is just under 50%. Seems to work as it should, especially the steering being tight. But I do want to grab another rear axle and overdrive it so I could also enjoy this thing on the trails.
