Harvo
Mine works just as it should for every function but one. The radio is set just like most everyone elses.
Rear dig has an issue. When throttling forward in rear only mode it works like it should.
If I reverse in rear only mode, the front motor pulls forward as the rear turns backward. It does that at the beginning of the trigger, then the front motor cuts out as it should at half throttle.
Most times I rear burn reverse at slow speeds, so the front motor turning forward really jacks things up :x
Any ideas?
Thanks"thumbsup"
Any ideas?
Thanks"thumbsup"
