OSRC
Rebuilding and modifying a 1/9 Kyosho 4Runner....Goal is more of a light runner since I have plenty of rigs to go beat on, and parts for this are super hard to find. Really cool and unique chassis, and well worth a rebuild.
Initial condition is a chassis that looks mint and a body that is totally, totally beat. Not sure how you do that, but oh well. I'll worry about the body later. As it stood, the drivetrain was turning really hard and the steering was super stiff as well. I started pulling it apart to see what I could do.
Front end setup: geared diff and steering in front of the axles. Super beefy suspension arms and hubs. Good set-up for its day.
Pulled off the front gearbox and it was filled with some sort of alien vaseline goo. Can see it gooped over the ring gear. Super thick and sticky and crammed in there - no wonder the front diff would not spin.
Hey! There is a gear in there!
Tore it all down, cleaned out all the goop and found a steel pinion, composite ring gear, and all metal bushings. Dug around in my parts bin and found a Kyosho Super 10 sealed diff with a nice metal gear attatched. Filled it with 100k silicone diff oil and and it dropped right in. Added bearings all around that I raided from some other kits, and got a much smoother, stronger drivetrain with a front LSD.
Cleaned and lubed all the joints, pins, parts and put it back together. Shocks were filled with 40wt oil. Suprisingly, they were both full already and no leaks, even as old as they are. Good stuff! Just refilled them so I know what's in there.
Next: steering and tranny
