picklewagon
Just got Mayhems for my berg and now my tires rub my shock springs in the front at full lock. Is this normal? Should I fix it?
Not a big deal I guess but it pops the spring off the bottom cap. I think I'm going to wire the spring to the cap. Hmn.. do they make some kind of captured spring cap?
-Eric
I have mayhems and have the same issue so I set the endpoints on my transmitter to stop just before they touch, my issue was the tires would run on the spring adjuster and tighten/loosen the spring preload. Now when the wheels are full lock, and tires are flexed over during a crawl, they touch a little but no biggie. I'm planning on installing a 2nd set of spring adjustment nuts and tightening them against each other so they won't move. I've used a drop of ca on spring cups before to secure to the cups to shock end but only a drop so you can break the seal easily to remove them!
