Highmark
I've been nose-deep in scale builds for years now, but before that I was a Comp Crawler guy (mostly Supers) and I competed most prolifically with a rig I named Alf. Alf started as the first torsion frame Clod Buster (what went on to be the Pimp Cane) and was a collaborative effort between Heavy, Myself and SycoRc. Alf went threw three phases back then, the first was a torsion frame using two long 1/4" aluminum rods that were tig'd together, the second was a solid frame with no articulation, with the last being Alf 3 (pictured below).
When I got back into competing I built the Super Scrambler as a Class 3 / TTC rig, went to Nationals in 2012 and learned a lot. The Scrambler was powerful and tough as nails, but it also weighed a lot and was basically an SCX-10 on 2.2's.
I've been on a nostalgia kick lately, so I thought it would be fun to bring the Alf name back, and maybe some of the character as well. I knew it had to be a F-350, so I started that and built the concept around that using what I've learned over the years. This will be a quick build (I started back in February), as I need to have it running for National's in a few weeks.
Build list:
Front Axle:
XR10 width - XR-10 universals
Rc Bros Brass tubes
Custom Carbon Fiber servo mounts
Vanquish C-hubs
Dlux knuckles
Rear Axle
CreationFab Derlin tubes
Vanquish C-hubs
vanquish knuckles
Chassis / Suspension / Trans
3/16" Ti links
Toyzuki Frame and T-Case (Holmes outputs, super shafter upper, HR gears)
Performance 3d Solutions Skid, T-Case cover and rear chassis brace.
SDI steel driveshafts
Custom bumpers
4" Big bores, internal / external springs and wickwolf caps with revo ends.
Electronics
Dual Hitec 7980's for steering servos
Hitec 7950 Winch servo with Maddogrc drum
Dual HH BR mini speed controls
Holmes OG cobalt puller
Thunderpower 65C lipos.
Wheels / Tires
CI 6-bolt wheels (350 hubs)
Custom 2.2 / 1.9" Pitbullt XL's
First mock-up next to the FJ45:
Getting Closer, It's taken a work to get this build done right due to the crazy - long wheelbase. We'll see how it performs!
Custom tar's, Pitbuill 2.2 sidwalls with 1.9 XL treads.
It's pretty tight up front!
I'll keep updating as I go, only a few weeks to go! :shock:
Build list:
Front Axle:
Rc Bros Brass tubes
Vanquish C-hubs
Dlux knuckles
Rear Axle
Vanquish C-hubs
vanquish knuckles
3/16" Ti links
Custom bumpers
Electronics
Wheels / Tires
