Thanks for sharing your setup. Things can be drastically different depending on what parts you run.
So, it shows them in stock and price is 0.00 and $5 shipping ?
are they in stock? I need some for my build.
Yep, as said above, if you choose the one you want, it will change the price.So, it shows them in stock and price is 0.00 and $5 shipping ?
For those of you running a U4 front truss along with standard VP knuckles, what are you doing about the steering arms hitting the end of the truss before reaching full steering lock? Different arms? Just space the arms up?
Anyone concerned about the serco hanging down below the axle tube ?
No, sorry. Since the SSD axles have the link mounts built into them, I decided to skip them.You don’t make one for the ssd centered ar60 axle do ya?
Any idea how soon the front sporty truss and mount will be available? I am starting a Wraith kit build but will hold off if it will be available in the near future. Thank you.
Yep, sporty trusses are in stock. For a wraith build, I would suggest a U4 truss though. They are much stronger. The sporty trusses are intended for sporty cars.
Dlux Fab
It would be the strength of the truss, not the strength of the housing I would worry about. Also, it puts the servo in a lower position where the U4 puts it higher.What out on an alum axle housing? Wouldn't need the strength then right?
Any idea when the front aluminum truss is gonna be back in stock?
Is there only one version available for the AX10/SCX10 style axles? Is there a discussion on that anywhere?
