Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to RCCrawler Forums.
can a set of these be made to replicate the plastic ends of the axle ?
like cut the axle ends off bolt the tube in mount scx10 hardware to the tube
replace stock shafts stock steering arm tyres and go ?
You can use the stock Chubs and knuckles if required. Simply lightly dremel out the stock Chub and slide over the splines. A round sandpaper bit works best. This way, if you upgrade to splined later you have the proper tubes.
The website is back up and running, sorry for the delay. We are now stocking Stainless Steering link kits, Axial Plastic Case Halves, and Vanquish C-hubs and Knuckles.
Are the delrin versions available anywhere still? I am running the aluminum ones in the front of my 2.2 sporty and delrin in the rear, but one of them is cracked. Anybody?
