Biomedchad
So I shouldn't open my mip ax10 driveshaft kit? Was going to use one for the front with the yeti rear shaft.
Just ordered a Holmes Puller Pro 2200kv. The pile of awesomeness continues to grow. I should've just ordered a cage. Then I could've called all the kit guys dumb. But then some D bag that bought the skid only would've called me dumb.
I used the wraith MIP with two short ends. Should be the same as an ax10 shaft? ax10 is actually better if it has the larger pins.
Quick vid around the shop. It's freezing and icy outside ;-)
3300kv Holmes trailmaster pro, mmp, 5000mAh Venom 3s 35c, 12/64 gearing (stock) Ran it in the parking lot for a second, carries the front wheel at will.
<iframe width="640" height="360" src="https://www.youtube.com/embed/ucKEADQxgBk" frameborder="0" allowfullscreen></iframe>
Wow, so that was in low range!?
For those of US that are waiting for our UPS guy to show up...it's gunna be awhile. Per axial "10 days until the next shipment. And 7 days after that for a second shipment"...........longest november/December of my life!!
I don't have the two speed, not something I'm interested in. So that's high range technically. It could use a tooth or two on the pinion, plenty fast for around here though. I have 6s stuff if i want to go 50 "thumbsup"
