Axial wraith with a scx-10 honcho frame
nathan000
Canada
Id like to be able to to put everything in my axial wraith on the honcho frame basically. I just find it too much of a hassle to get at the electronics and transmission of the wraith. So my question to you is would all the stuff for the wraith even fit on the new frame? ie wraith transmission fit on honcho frame. Also is the 4 link set up for the wraith even compatible for the honcho body?
Are you trying to take EVERYTHING and put it from the Wraith down to the SCX10? The transmission will mount right up with no modding. I think everything else you are doing will just take an attempt to see if it will work. If you have the right tools and a little know how anything is possible. Good luck, you should take lots of pics during this build.
Zonkered, here on the forums has one. The tow truck which is axial wraith axels and an scx10 frame. I'll search to see if I can find a thread on it. Seen it in person and it's bad ass.
why? they have the same trans, you can use wraith shafts, and just swap wraith axles under your scx10. its been done. ill take whats left of your wraith.
I've done this, just to try it out I bought the same "Tamiya Upper/Lower Suspension Stay 47201" Bender did for the three link
